Problème demarrage - batterie ok
Message Problème demarrage - batterie ok Répondre en citant
check fusible
Mer 12 Aoû - 20:12 (2015)
Obscure
B1006 Accessory line overvoltage instrument
B1007 Ignition lie overvoltage instrument
Donc si je ne dit pas de connerie, surtension donc vois pour effacé les défauts et essaie de redémarrer, si c'est bon, contrôle la tension au borne de la batterie , tu a peut être le régulateur HS .
Et 2 injecté sauvé
Mer 12 Aoû - 22:01 (2015) MSN
Edo
Le raccord rapide d'essence sous le réservoir est bien enclenché ?
Edo
XR1200x - 2010
Le Sportster pour les nuls : http://xr1200x.free.fr/
Mer 12 Aoû - 22:08 (2015) Visiter le site web du posteur
Don Long Juan
Cà y est je parle angliche... Mr. Green
Code B1006 will be displayed when line accessory voltage is greater than 16.0 Volts for more than 10 seconds.
This is telling that your instruments are geting to much
voltage should be 11.6V-13.8V
i would check the voltage regulator probably it is faulty, check also the Battery ground cable !
According to the Electrical Diagnostics manual
The codes you mention come under the issues of "Accessory or Ignition Line Overvoltage"
Furthermore, Ignition and accessory voltage is constantly monitored by the speedometer (terminal 1 ignition and terminal 6 accessory). If
the battery voltage fails to meet normal operating parameters, a DTC is set.
• DTC B1006 is displayed when accessory line voltage is greater than 16.0 volts for longer than 5 seconds.
• DTC B1007 is displayed when ignition line voltage is greater than 16.0 volts for longer than 5 seconds.
As others have mentioned the fuse and relays need to be check/cleaned and coated with dielectric grease.
I would also add the following connections to clean and grease with dielectric grease:
1) Speedometer and Tachometer connections
2) Voltage Regulator Connections
=> Le 8 carbu alias El Viento
=> Le Gros Bob
Mer 12 Aoû - 22:15 (2015)
jackololo
very well, Pascal Okay
Mer 12 Aoû - 23:23 (2015) Visiter le site web du posteur
Tiidadii a écrit:
Hello
Je suis en vacances en Alsace ( Haguenau)
J'ai fait le trajet depuis la région parisienne
Quelqu un a une idee ?
Putain!!! T'es fou!!! Shocked Shocked
Soldiez l'a bien dit: ce sont pas des bécanes pour rouler... Faut pas sortir du paté de maison! Mr. Green Mr. Green Mr. Green
Bon, blague à part, le soucis avec une surtension c'est que ça peut faire claquer pas mal de truc.
Commence par vérifier les fusibles (si c'est pas déjà fait).
Mer 12 Aoû - 23:43 (2015)
Don Long Juan
Okay Mort de Rire
=> Le Gros Bob
Mer 12 Aoû - 23:53 (2015)
Obscure
Avec Google translate :
Code B1006 sera affiché lorsque la tension d'accessoires de ligne est supérieure à 16,0 V pour plus de 10 secondes.
Ceci est dit que vos instruments sont Geting à beaucoup
tension doit être 11.6V 13.8V-
Je voudrais vérifier le régulateur de tension il est probablement défectueux, vérifiez également le câble de masse de la batterie!
Selon le manuel de diagnostic électriques
Les codes que vous mentionnez relèvent les questions de «accessoire ou allumage réseau Surtension"
En outre, l'allumage et la tension de l'accessoire est constamment contrôlée par l'indicateur de vitesse (terminal 1 et le terminal allumage 6 accessoire). Si
la tension de la batterie ne parvient pas à satisfaire à des paramètres de fonctionnement normales, un DTC est réglé.
• B1006 DTC est affiché lorsque la tension de ligne d'accessoires est supérieure à 16,0 volts pour plus de 5 secondes.
• B1007 DTC est affiché lorsque la tension de la ligne de contact est supérieure à 16,0 volts pour plus de 5 secondes.
Comme d'autres l'ont mentionné le fusible et relais doivent être vérifier / nettoyé et enduit de graisse diélectrique.
Je voudrais aussi ajouter les connexions suivantes pour nettoyer et graisser avec de la graisse diélectrique:
1) Indicateur de vitesse et le tachymètre connexions
2) Connexions du régulateur de tension
Tu a démonter ton câble de masse, il est bien revissé par hasard ? sinon après il faut que tu contrôle la tension au borne de ta batterie et si elle est sup a 13.8V ton régulateur est peut être HS
Et 2 injecté sauvé
Mer 12 Aoû - 23:56 (2015) MSN
Don Long Juan
Merci obscure Okay
=> Le Gros Bob
Jeu 13 Aoû - 10:05 (2015)
ben pour tester la tension aux bornes, faudrait deja qu'elle demarre Mr. Green
Et ca peut etre mesure a 14.5 sans probleme. C'est au dessus que ca craint
Jeu 13 Aoû - 11:27 (2015)
jackololo
+1200
Jeu 13 Aoû - 12:48 (2015) Visiter le site web du posteur
Tiidadii
Bon plan d action on repart en région parisienne comme prévu on va pas se ruiner les vacances, on est déjà assez dégouté fe pas avoir pu faire une journée en forêt noire Evil or Very Mad
Je reviens la semaine prochaine jouer au mécano dans le garage de môman comme au bon vieux temps Cool
Avec 2-3 choses à faire qui ne feront pas de mal à la bête
- changer les bougies pour des ngk irridium
- il me semble qu'il manque un fusible (tout en bas à droite) les autres ont l air ok
- recharger correctement la batterie
- j'envisage de changer le régulateur de tension
La je ne suis pas équipe donc je pourrais revenir avec les outils nécessaires, et donc impossible de tester grand chose!
Je vous tiens au courant mais déjà merci pour votre aide Mr. Green
en route vers mes premiers km en duo!!! Me reste juste à trouver des coins discrets et sympas pour concrétiser les vibrations!!!
Jeu 13 Aoû - 13:15 (2015)
Baduk
et t'as resserré les cosses tout simplement ?
Jeu 13 Aoû - 17:44 (2015)
Obscure
Déjà, tu a regarder si le câble de passe est bien resserrer ? (sur la batterie ET sur le moteur ?) .
si tu a un attelage, je peut te prêter une remorque pour récupérer et ramener ta moto ici (je suis pas loin de chez toi) .
Et 2 injecté sauvé
Jeu 13 Aoû - 17:46 (2015) MSN
Tiidadii
Merci mais pas d attelage
Merci beaucoup
Jeu 13 Aoû - 19:49 (2015)
Aujourd’hui à 09:17 (2018)
Page 2 sur 4
